Manual / de-powered steering rack
MattDaKav
New member
Hi,
I'm after a manual rack or a de-powered rack, or someone that will de-power my rack for me.
I'm based in Surrey.
Cheers.
Hello fella I have just de powered mine, it’s not that hard. Just have to find someone who can weld the pinion up, unless you have a welder ;)
It's not really is it...
You have to remove the rack from the car, strip the entire rack down - including removing the rack section as well as the pinion. So that means removing the track rods, replacing the lock washers with new parts along with a few other bits.... then remove the seal from the rack that sits towards the passenger side. Oh yeah you will probably have to buy a couple of correctly sized sockets to undo everything but then like most RX7 owners you could just make a bodge job of the whole thing and use some grips, re-use all the components that are supposed to be replaced and then wonder why your car sounds and drives like a bag of bolts.
I love how over simplified people make this.
I tried to get hold of Gavbey when I did mine, he responded once or twice and then seemed to go incognito, add that to the hassle of shipping the thing to someone I decided to do it myself, using proper blanking caps on the ports not welding them up.... That all added some cost to when I did it.
Don’t you love it when someone makes a job sound simple and it turns into a pita.
Still much simpler than
Changing your clutch
Replacing all brakes
Removing engine
Rebuilding engine
Fixing the twins
Ect ect ?
Tbf nothing is really that hard on the fd! It just all takes time!
Let's not turn this place into a bitch parlour lads ey ? take it to rx7 club as they love that kinda stuff over there ?
Hello :),
Sorry dude, ever since becoming a dad ive had little time to build my own cars let alone doing racks for people for near zero profit.
I generally done them for £50 and that was posted back to the person . took me around 8 hours to do properly.
If anyone is interested i could build a guide.
Ive done 17 racks so far.
