Heater controls
Efini-dan
Looking for ones to replace this type.
Thanks.
Good luck is all I can say! That’s a climate control panel and they go wrong all the time. That and they’re a nightmare to find. You might be better served trying to repair that one.
Ah bugger, it did flash all its lights and sort of worked then stopped completely in the end.
Is the car harness the same as a normal one? I'd stick anything in there as long as I have a demister. I'm not bothered about climate control to be honest.
I beleive it’s different inside the car in terms of harness as well
Ah great, I'll do some digging then and see what I can fix or make work.
Thanks jit
Worth opening up and having a look to start. Mine had corrosion on the tracks and bits stopped working, cant see how water could have got in but a drop had. Lost power to hazards, had to bypass with 2 wires. Not tried it yet so cannot say if it works yet
Yeah I just had a quick look and there's was some obvious corrosion on one chip on the control knob side of things but I gave it a clean and still no joy.
I just found a complete one on ebay for £35 so I'll see how that goes.
