Feed rear arch and cutting
Caine_1989
Hi I'm going to be ordering and fitting some feed rear arches I've got a general idea of where to cut the standard arch etc what have you done to seal the wheel well back up did you weld it I know you have to do something similar to the pics below
Given the feeds are not a huge gain in width I’d be looking to pull the stock arch out 20mm rather than cut them up.
I should be able to fit the wheel I want already I've got 25mm I could push mu current setup outwards it was just for the look of the car mainly
I mean add the feed arch, but rather than cut underneath, just pull it out to meet the feed rear
