FD Wiring Specialist
Robbie98
Hi guys looking for someone who knows there way around an FD especially the gauge cluster.
I have a universal loom coming off my Hondata Kpro V4 ECU and need to splice and connect the correct wires to the RPM, Speed, Oil and Temp on the cluster
If anyone's knows anyone could you please let me know
Many thanks
Robbie
Here are some resources you may find useful
I suppose the first question would be are you splicing next to the instrument cluster plugs, or next to the ECU plug?
Diagram for the cluster:
Just figuring it out exactly, I'll let you know if I work out what wires to cut but I thought I'll give the diagrams in the meantime...
I was expecting one speedo wire but there were two, hence why I was confused, it should be
speedo: 3C 3A
temp gauge 1D
temp light
oil pressure 2F
oil light 3J maybe?
tach not sure yet
fuel 2B
fuel light 2C
ignore the second page I sent thats just illumination I meant to send the other half but I dont think its too pertinent to what you need to look for:
speedo: 3C 3A
temp gauge 1D
temp light
oil pressure 2F
oil light 3J maybe?
tach not sure yet
fuel 2B
fuel light 2C
Much appreciated mate thanks alot :)
I also got told that there was a loom/connector which plugged into the ECU right below the AC unit under the dash - it has a speedo sensor wire and RPM sensor wire which your meant to splice into and connect to you universal harness.
Any info on that :unsure:
Check this comment from (jimlab) seventh comment down - https://www.rx7club.com/3rd-generation-specific-1993-2002-16/speed-sensor-271337/
