The flashing exhaust temp light on your RX7 could indicate that the ECU has detected an issue with the exhaust temperature or engine performance. Since you're running an Apexi ECU without the hand controller, it may be harder to diagnose specific issues directly. You can use an OBD2 code reader (if compatible) or look into getting an Apexi-compatible controller or a specific ECU diagnostic tool to read the codes. It’s best to check the manual or online forums for your specific ECU model for further guidance.
