Coolant Level Sensor
welshkid
Anyone got one laying about? Not the temperature one, the one for the fill coolant buzzer on the water neck
Cheers!
Yeah, wire completely missing from it (found it grounded near by), not enough meat on it to solder a new wire with a strong enough connection, really annoying
You can stick a heat gun on it and dig the glue out, you can solder direct to where it needs to be then! You just need to watch you don't melt the plastic nut 👍 literally a 20 min job 😉
its just a spade connection so you could cut and crimp one on
