Clifford Concept 300 Removal?
timmymagicrx7
I'm looking to remove my Clifford Concept 300, as it's a real pain. Does anyone know how to do this, or know someone who can take this on for me, please?
North Essex Area.
I just got in there and starting trying to trace wires to work out what was where when I deleted my old alarm.
Lots of spliced wires under the dash and into the wiring behind the panel by the driver's door hinge
I took the dash out to be able to do it.
I think theoretically you could've done it with the dash in, but it was so hard to see behind the gauge cluster etc.. it was a lot easier with it out.
Once I had found the splices into the main ignition/start wiring that comes out of the ignition switch it got a lot easier.
even with trying to validate connections with a multimeter as I went I was still crossing my fingers that the car would start again once I'd taken it out.
I suspect that each one would be kind of different depending on how the installer fancied doing it though
Contact Clifford (Gap security), I had a Concept 300 and the alarm would go off randomly and sometimes the fobs wouldn’t shut it off so removed and replaced with a 650. I had a look at removing it myself and when the guy replaced mine, it was a right mess behind the dash and would have caused more issues if I had of tried. I had a big box of old wires/fuses/relays after it was taken out.
