- Apr 11, 2018
Hi im after an alternator plug with a decent amount of wire so i can rewire mine if anyone can help its the grey part at the bottom with enough wire to reconnect it to my existing loom
SignUp Now!Awesome cheers ive just ordered that one from amazon i broke my plug a while ago and rewired it but think it on its way out as i cracked the plastic and had to use those terinal blocks to connect itThis is a part that has been confirmed to work on RX7club forum: https://store.alternatorparts.com/partnoc1900.aspx
This looks like the same part (not confirmed)
https://www.amazon.co.uk/dp/ALTERNATOR/?tag=fdoc-21
As does this (not confirmed):
https://www.rotatingelectrics.co.uk...ernator-repair-plug-2-wire-pin-pigtail-pl4-wl
I found this one: http://www.nzefi.com/product/common-2-pin-alternator-connector-suits-nissan-mazda-mistubishi-etc/I used this one and it works:
https://www.ebay.co.uk/itm/262889129078
I only replaced it as the insulation around the wires broke up near the plug, I still have the parts around somewhere as I was trying to find replacement terminals.
What I really want to know is the actual part numbers for each of the components of the connector because I want exactly the same and pretty sure you'd be able to buy just terminals from somewhere in the EU.
Mines turned up and im going to test it tomorrow will let you know what it fits likeDefinitely worth checking the dimensions for these, as they could be for the fuel tank connector plug. I was looking into the connectors/ terminals for both of these at the same time.
