00-02 abs unit
ZKMotoring
Hello looking for an abs pump and connector from a 00-02 fd. Bosch 5.3 pump
Looking to do a later model abs swap on my 96 rx7
You probably should check if you need to get a matching ABS Computer. Is a 96 a 3 way and a 02 a four way ABS.?? Worth checking
The ABS module is part of the pump on the last iteration of the FD ABS which makes it easier.
Yes, the the later model FD's from 00-02 RX7 has the Bosch Unit with the ECU onboard. The ABS Swap isn't hard either as I have been looking. The wiring is simple and will only need to be extend to the rear of the trunk where the old ABS ECU is. Cut the connector off and use connectors to make it all plug and play.
I know lots of Japanese Tuners do it too! There used to be some sort of magazine about it too.
