Any Alternative Seaming Welt Seals? (Body to Door)
Project Tiger
New member
Hi All
Are there any alternatives to the body-to-door seaming welt seal as pictured below? My right-hand one is needing replacement and £300 is a bit steep for a bit of extruded rubber.
Either a reasonably priced alternative or off-the-shelf seals that can be cut to length
I'll make my own if need be, I've seen another for £77 - again it looks off the shelf and cut to size (https://reflekt.engineering/blogs/news/rx-7-fd3s-body-door-weather-strips-now-in-stock). Anyone had any luck?
Thanks! :)
The one you've linked has been doing the rounds on Facebook, I can't vouch for the quality or company but probably worth a punt unless you want to do the trial and error
I've found a seal profile similar to the one from Reflekt, I'll give that a go first and see what happens!
I've been seeing the same. It is always difficult to be the first to try a new product, no one wants to be stung! But if its good, then we'll all buy one :)
