- Nov 18, 2018
Looking for a bit of advice to see if I'm in the right direction
The other day I went to start the car and it turned over as normal but wouldn't start, left it 10 secs tried again and it started on the second crank, went for a drive and all seemed OK
Tried again the following morning and the exact same thing but this time driving the car it cut out once and twice felt like it was away to stall but revs picked up
I noticed when tuning the ignition on I cannot hear the fuel pump prime/run
I have tested the ignition to the second position there is 12v to the pump connector, along with 6v which I'm guessing is the fuel sender
I have ordered a new fuel pump as I'm thinking that's where the problem is and was going to get the fuel filter changed on the service in a few weeks anyway
Is there anything else that could cause this?
