- Jan 10, 2018
So you want to go single turbo?! Welcome to the club.
I thought id wright up this thread to give a list to what you might need to build yourself a single kit.
diffrent goals will require diffrent kits, porting etc will also change your choice of setup but ill keep this simple as i can.
You will need:
Turbo (T4 is most popular footprint)
Air filter to fit your new turbo.
Single turbo manifold (i use 3mm ebay)
Oil lines (AN4 commonly)
Oil return lines (AN10 Commonly)
Oil return fitting.
Boost pipes.
Wastegate. (50mm is commonly used on rotary engines for most boost ranges. Also id recomend a genuine make such as tial or Turbosmart... Ive tried all sorts of ebay gates. they die)
Wastegate dump tube.
Downpipe (Generaly custom made. x2 45deg bends and a short legnth of straight. ( diffrent turbos have diffrent flanges etc)
Dump valve. (users preference whether to run one or not)
Block off plates
Fuel!- bigger injectors, pump (Direct feed (relay modification))
Adjustable FPR
Intercooler kit (FMIC or VMOUNT)
ECU (Power FC)(Adaptronic)(Link)(ME) & any tuning stuff you may want (WB, Dataloger)
hose for wastegate (id recomend 4-6mm ID)
And a lot of other stuff that will probably need upgraded if not already.
Wideband (AEM, INOVATE)
Boost Gauge
Boost controller (If runing more than wastegate pressure
Colder plugs, 9, 10,11 (depending on hp Craig TGS has made a thread for selection)
Ignition (HKS twin power) (AEM Smart coils)
Bigger Radiator
Better Clutch
Motormounts
BOV
Water/Alc injection
Full 3" exhaust
Battery relocation
Pulley kit (remove air pump)
Diff brace
So in many ways its not just a case of buying a turbo and manifold and sticking the hoor on.
Hope this helps some people looking to go single.
Every thread needs to have a little picture. Heres my messy build. not a kit in sight.
You will need:
Oil return fitting.
Boost pipes.
Block off plates
Adjustable FPR
Boost Gauge
Bigger Radiator
Better Clutch
Motormounts
BOV
Water/Alc injection
Full 3" exhaust
Battery relocation
Diff brace
