So this was the extent of snow we got in Somerset:
tn_WP_20171210_15_51_26_Pro by
Tom Kinsman, on Flickr
Very disappointing I must say.
So the winter project is well under way and the end is sort of in sight
tn_WP_20171219_10_12_47_Pro by
tn_WP_20171220_12_03_45_Pro by
tn_WP_20171220_13_10_16_Pro by
tn_WP_20171220_13_47_49_Pro by
All the bolts etc are in good shape. After plating they should last well
tn_WP_20171220_11_15_26_Pro by
Everything is being painted with epoxy, few more coats to go on these..
tn_WP_20180110_18_27_33_Pro by
tn_WP_20180110_18_27_50_Pro by
tn_WP_20180110_18_27_59_Pro by
tn_WP_20180110_18_28_10_Pro by
Picked up a few more SR bits, because it is so close to being full SR spec that it would be rude not to
tn_WP_20171213_18_16_12_Pro (2) by
tn_WP_20171220_19_39_08_Pro by
I've been pretty bad at taking pictures recently, I've actually done loads more, just haven't taken pictures of it all. I'll catch up this weekend if I get time
Tonight the diff is being stripped to swap the crown and pinion from a 4.1 final drive to a 4.44, new seals, crush tube etc. This will be the second attempt, this time with a proper bearing press tool, I got stuck last time trying to remove the bearing near the pinion gear, there isn't much to go on with a press without risking damage to the bearings, so I didn't risk it. Fingers crossed that'll all be fine tonight so I can crack on with the gearbox bits and start slinging the car back together soon
Other bits done that I don't have pictues of:
New tie rods.
New track rod ends.
New rack boots.
All suspension arms have new pillow balls and super pro bushes, all joint boots replaced also.
New brake lines.
New wheel bearings pressed in.
New rear brake dust shields fitted.
Hoping to get the arches and underside painted over the next couple of weeks. Still got the fuel tank to go too. Getting there, though
