Very Rare Knight Sports JDM Front Bumper With PIAA Fogs
RichLeeRX7
This was all on the car when it was imported from Japan and believe it to be a genuine very early Knight Sports front bumper. Extremely rare now.
I'm putting everything back to standard so up for sale.
The fogs include mounting brackets that mount on stock bolting location.
Also, have the proper PIAA Relay system which is about £60 new.
Had a minor bump on the front offside and will require a minor repair. Easy if you can fiberglass!
Strictly collection only from Wolverhampton area.
£250 ono
I was curious if you still had these. I have this bumper myself and am trying to find foglights I can use. If you have any information about them like the outer diameter, the piaa model and also how the bracket mounts these to the car it would be much appreciated!
I have these on mine, the rear bracket isn't anything special , just a right angle of metal with a few holes, I can measure mine when i get home tomorrow if it helps, but they pretty much just fill the hole/aperture up.
you will need a relay of course , i have the PIAA one fitted, but i guess any decent relay and fuse combo will work
That would be be much appreciated! Also is the relay mounted where the bumper support would typically be mounted? Your car looks great by the way is it the full early type aero kit?
the relay can be mounted anywhere really dependant on length of wires, mine is on a bracket by the shock tower.
It is the original kit, there were two brought over by Rotary Imports about 2004/5 mine is Red with white wheels and stickers
the other was White with red stickers although painted Met. grey many years back since and had the body kit blended.
I can measure the diameter of the lamps tomorrow.
P.
