Sequential boost controllers info required
Jake_rorx7
Hi all,
Does anyone have any info regarding boost controllers for the sequential system? I came across the kightsport EBS iii or EBS IV which can have a sequential adapter, but it's unclear whether this would involve some sort of parallel conversion. Does an aftermarket boost controller for the sequential really exist in a true sense - i.e Contains a MAP sensor and has target/actual boost control, controls sequential system as standard...
I think this is something the ECU usually controls (boost levels but what about changeover? Is this done on electronic valves too?), but let's assume for the sake of the thought experiment that you are running a stock ECU, or an aftermarket ECU with no sequential control, yet wanted to retain sequential working.
There is info on these but it's just difficult to find.
Cheers
