RX7 LS1 V8 rebuild
Mar71n
Called into DynoTorque to drop some more parts in & they've been busy bolting stuff to the car :)
I'm not going to run the diff cooler. concentrating on getting the car back on the road.
Mar71n
Got half a day in on the car yesterday. Finished off the hand brake cables I'm using a hi Spec spot caliper which is supplied with a universal cable with some small clamps that you use to attach to the original hand brake, it's a bit crude so I made two nipples out of stainless with a grub screw in both ends. It was a bit of a wrestling match to get any tension on the cables.
Then started on the exhaust, I can use the system I used before but will have to modify it to get round the nose of the Ford 8.8 diff.
Reactions: tomCTR and Tjp8
Mar71n
Screen out so Craig can get at the wiring easier & for when it gets resprayed. No other progress this week as he's finishing off some other cars & I snuck in before they turned up + a lot of the parts that have been fitted up till now have already been built up.
Reactions: tomCTR and giryan
Mar71n
I was using a KnightSport kit but after seeing the Hella lights on Paper Cups car I wanted that set up. Craig said you can @%$£ off & do that yourself. The lamps arrived lasr week so gave it a coat of looking at on Tuesday & spent today modeling it up so I can get the mounting 3D printed. I ran out of modeling talent so the guy with the 3D printer I use will have to finish the model off so were into next week befor I get the 1st off print.
Reactions: giryan
Mar71n
Advocult motorsport oil coolers & the fuel lines are finished. The air con kit has turned up but waiting on the radiator & fans. Hopefully I`ll get a couple of days free at the end of next week so I can mount the radiators & start on the air box..
Reactions: shaunwil and tomCTR
Mar71n
Off to a good start with the 3D print
I'm going to use the KnighSport shroud so have off set the lights like the KS kit
Looking like it's going to work
Er no, realy please for the first attempt though. I've bought 3 rolls of filiment for the 3D printer so will remodel the mounting & have another go.
Nec classic car show
