SignUp Now!Looks identical to my own, look forward to seeing updatesThought I would start documenting my build, so here it goes
Picked up a 1992 RZ 11/08/23 Not the best deal on my end but you live and you learn.
Long story CBA to talk about it lol waste of energy. Still debating on the engine will prob stick to my plan and go K20Not the best deal as you didn't realise it had no motor?![]()
V6 twin turbo come onLong story CBA to talk about it lol waste of energy. Still debating on the engine will prob stick to my plan and go K20
Always wanted to do a V6 swap on an RX7 as its a different path to the V8 which everyone's does. Just haven't got the budget LOL plus I want to keep the 7 jap theme so K20 is the way forwardV6 twin turbo come on![]()
Plenty of choices with v6 bud! but completely get it!Always wanted to do a V6 swap on an RX7 as its a different path to the V8 which everyone's does. Just haven't got the budget LOL plus I want to keep the 7 jap theme so K20 is the way forward
Yeah 300 in the first instalmentYh I believe so, I've read that there are around 300 units but I could be wrong and might be reading about the Spirit R
'92 broIs it a 92 rz or 93? the strut bar and wheels are not from a '92, could have been changed though. Can run a VIN check for you if you like. The 93 is a lot more desirable than the 92, gets the decent brakes etc (Although judging by the amount of brick paranoia going on I'd assume the brakes a gone).
Ahah was thinking about it but cba, I want to carry on the build I set out to doOnly 300, I'd be putting a rotor back in it lol
In other words you are winningThat's a 93 model year RZ, but was made on 09/09/1992, so one of the first batch in the 93 spec so would have had the larger brakes, 17" wheels it has now, bins, recaros, 4.3 diff and .762 5th gear. So it's better than a '92 RZ, it's a '93 RZ.
Are you going to convert the release mechanism?Picked up a S2K transmission Friday needed a good clean. Looks good
Nope, Why? is there a better way.Are you going to convert the release mechanism?
