New to me rx7 fd boost issues.
ajcascio
Hi All, first time posting as ive recently aquired an FD Series 8. Very new to the rotary + sequential turbo world. The main issue ive ran into is im having an issue where i practically lose all boost entirely. it boosts fine for maybe 5-10 mintes every time i first drive the car that day, then after that it looses all power and just about makes it out of vacuum on the boost gague. It also has a very loud squeak/hissing sound that i initially thought was coming from one of the belts but then realised its only happening at around 3k rpm which made me think it might be a loud air leak hence the turbo issue. The fact its intermittent and the turbos clearly work (when they want to) gives me confidence the turbos themselves are fine and hopefully its something smaller, just a case of finding that issue. Is there anything these symptoms point towards in anyones knowledge? I think realistically ill be replacing all the vac lines along with check valves and the solenoids as the system is pushing 30 years old now, just want to know if theres anything to look out for while the upper manifold is all off.
Sounds like possibly a boost leak.
If you are going to be working on these your self the best thing to buy is a smoke tester. Takes a lot of guesswork out of finding issues.
I smoke my impreza every service as stuff ages and o-rings and rubber perishes its proved to be invaluable.
Have a look at the check valve under the tank behind the alternator. See if it’s still one way (or even in one piece)
So only doing it when it gets hot? Sounds like a solenoid issue. I've forgotten the proper flow for the twins system but maybe turbo control or charge control. Read this:
https://www.rx7club.com/3rd-generat...t-simple-sequential-setup-how-do-i-do-886474/
It looks that way mate, I'm not putting my foot down at all till it gets to operating temp though (which it will boost at for a short duration) for obvious reasons but logically must still be heat related. I'm probably going to change the wastegate/precontrol solenoids as well as the two turbo contols. along with changing the hoses to play it safe and hopefully that cures it. Will have a read of that later thanks. (y)
Had a look today and that check valve is fine. also pressure tested the tank and holding pressure fine
I have since replaced the solenoid box. Took for a drive and car was boosting well till around 4500 then started to over boost and cut power. Took all apart again to double check anything and found that someone previously had blanked the turbo control solenoid line that should have been going to the actuator, only god knows why. Put back together with that routed correctly and now cars only making boost on secondary turbo. Any ideas? It’s strange as I don’t see why the turbo control has seemingly stopped the primary turbo working entirely
