What dimensions are they. I'd even look at using something like this (they are used in press tooling) :
Shoulder Bolts, Screws & Nuts
We have a wide selection of shoulder screws to meet your requirements, including shoulder bolts for injection moulding, all made from quality materials. Next day delivery , UK supplier.www.berger-tools.co.uk
Then make a copper washer for the crush washer.
There is play in the subframe bolts and it can shift. These square it up.
It's as much a case that you return the frame in to the same position after you have removed it.
Everything has a tolerance and this clearance is also to guarantee that they always fit together.
Once its clamped up it shouldn't really go anywhere. That is why there is adjustment there in the first place.
So not really much point then. I could half understand the copper washers just to give a better seat between the mating faces.
Probably not as important as other cars.
Theres also the locating dowels to line it up.
have you got any pics of or is there a build thread on this?
Thise locating dowels are not a snug fit into the chassis. There is still play. These keep it centred. I’m not saying they are needed at all, but in theory you could do a full alignment then drop the subframe and it would go back in exactly the same place.Theres also the locating dowels to line it up.
