Engine Bay pic thread
I'll dig out the usual images, currently its a bit dusty in the garage at the minute (car on axle stands though). It was some progress images while I did the job. I've put the brake master and clutch cylinder back in the engine bay since then.
I'll post some current ones when its back on the ground and cleaned.
No thermostat, the pump is on a solid state relay controlled by my ECU. Got it on a map that takes heat and engine revs into account.
