- Apr 5, 2018
Just had some paint work done and car has come back with a weird fault,
the Front N/side light works ok until the indicator or Hazard comes on then flashes instead ?
the front and rear bumpers were off while painting .
I've checked all the lamps around the car in case the wrong ones were in somewhere and all plug couplers/connections
and for wire damage but all seems good ? and checked the earths, which I guess its feeding back wards from somewhere
OR would this be controlled by the F110 CPU outputs ??
any thoughts as going mad with this one !
