Tried to get car started again yesterday has been fine prior to this , got fuel delivery , got spark , compression is fine although not checked even pressure with plugs removed , whilst cranking get a white mist from turbo intake and exhaust it’s not heavy and it’s fuel not coolant , did the champagne test whilst it was running and get the odd bubble which I’m guessing is the water pump but no constant pressure or small bubbles , could it be injector related as secondary’s are newish and no idea on the primary’s , also sometimes there’s a random humming / vibrating noise when you turn the key to start , any help appreciated cheers
