N Nick Member Joined Aug 12, 2024 Messages 80 Oct 21, 2024 #1 Took off the coolant hose from beside the throttle body. The pipe is split and corroded Any Idea if this is a replaceable part and where would I pick one up.
jack.am Well-known member Joined Jan 9, 2018 Messages 1,033 Oct 22, 2024 #2 It’s pressed in. You could pull it out and tap it for an NPT barb, I would just delete the double throttle and cap that hose run personally.
