- Jun 30, 2020
Hi all, I'm working on an Arduino project and I would like to get an intake air temperature reading into the microcontroller. Two possibilities:
1. I add a new IAT sensor somewhere after the intercooler, or
2. I tap into the existing sensor lines
What is the best way of adding a sensor into the air stream? Is there any unused ports under the manifold I can conveniently add to? Perhaps I can use the bunged 1" port on the back of the elbow somehow? Don't really want to be drilling and tapping holes on the manifold.
Will the signal between ECU and sensor be affected if I tap into it for a voltage reading? Is it even a proper voltage reading or a resistance measurement? Does anyone have any experience with doing something like this?
Cheers
Cheers
